OT - DC Motor as Tacho - smoothing - what capacitor
BryanG
Feb 2005
Manchester
1,987
Somewhat off topic but wondered if anyone could give me a place to start. Last year a customer wanted a very rough and ready and cheap speed indication for a machine and they needed it quick. I had a permanent magnet DC motor available which I used as a tacho, and fed the output to a Lascar Panel Pilot M set up as a voltmeter with graph:
http://www.amazon.co.uk/gp/product/B00AUCGD2W?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00
http://www.panelpilot.com/panelpilotm
It is working remarkably well but they are getting an occasional speed glitch and want to add smoothing, which I am guessing would be a capacitor and maybe a resistor. Can anybody give me a clue what size and type of capacitor to use? The motor can run forward or reverse so I guess that electrolytic is no good.
Really need to know the ripple frequency of the signal.
But, a variable resistor should help by trial and error.
The cutoff frequency of a low pass filter is 1/(2*pi*R*C)
For 1uF and 1k ohm = 160Hz
For 1uF and 10k ohm = 16Hz
Anything far above these frequencies will be blocked, but anything close you will still see.
A 10k variable resistor will give you a range of 16Hz @ 10k to 160kHz @ 1ohm. Note in the last 10% (from 1000 ohms to 1 ohm) the cutoff frequency is greatly affected (160Hz @ 1000ohms to 160kHz @ 1ohm). This may help you find the R value that works.
Hi HJTRBO
Thanks for the quick reply.
If your output voltage is within 100V
Motor is 24VDC at its maximum speed, so we are well within the 100V
Bipolar electrolytic capacitor
Hadn't heard of bipolar electrolytic capacitors, learn something new everyday.
More like 1/2 or 1/4 Hz. I will probably send them a few capacitors and they can stick them in parallel till they get the smoothing they require. Can they just stick them across the motor/tacho leads. Normally I know you have RC circuits but the motor will have resistance anyway.
for how many month ?
I know that this isn't high tech engineering. I would have liked a PLC, HMI and an encoder to monitor and control the machine properly, but instead they have a guy watching the output from the tacho and adjusting the speed of the machine. So long as it is near enough, it is good enough. The machine is run off car batteries and lives underground.
For 1/2Hz I would try 1uF and 10M ohm. This gives you a filter time constant of 10 seconds (Time for output voltage to rise to 63.2% of input voltage). If that's too sluggish lower the R value.
1uF and 100k = 0.1s
1uF and 1M = 1s
1uF and 10M = 10s
1uF and 100M = 100s
Edit: I made a quick spreadsheet for you to have a play with.
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
175
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
303
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
157
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
359
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
223
