Depends on your application. If you need to have an automated lubricating system then Graco mentioned above or Trabon would be a good choice. The metering blocks you pick for your system will determine the lube/grease amount, which is further adjustable at the pump. These are generally used to perform automated maintenance removing the obligation from the maint dept. Our specific application required a specific amount of grease to be dispensed inside a steering column bore. This was measured by pulses provided by a prox switch which was activated by a gear that rotated as the dispensed grease was pumped. We had actually used 2 different mfrs and the one I posted above turned out to be more reliable. Hope this helps.
