Okay, here's what we found once we could get into the machine today:
Reminder:
"A" side extends the cylinder.
"B" side retracts the cylinder.
Since the problem and focus has been on air or contamination on the B side, my first step was going to be to disconnect the hose from the cylinder and I was going to shift the valve to blow out whatever might be in that line. So, cylinder disconnected, line from valve put in a bucket, pumps on, shift valve.........and nothing comes out.
After another 30 min. of poking at things, some swearing, and pulling the drawings out again, I finally figure out that the drawing is wrong! There is an extra valve in the stack and I'm kicking myself now because it all comes back to me at once.
Remember I said that there is a heavy tool on top of this cylinder. Late in the machine build (actually after runoff) they added a "blocking valve". The valve is supposed to block the "A" side closed so that when we enter the robot cell (this is all in a cell) and when hydraulic power is killed, it holds the cylinder extended. When the machine is in cycle, the soln. on the valve is energized and it opens the blocking valve so that the cylinder can move as-required. I totally forgot about this thing. Apparently so did the guy who did the hyd. drawings.
So this valve body has two "holes" on each side for a valve to go into.....one for each circuit I imagine. One side has the blocking valve and the solenoid, the other side has what looks like a plug.
I think this "plug" looking this is totally blocking the "B" side in both directions. It would explain everything. I can't try removing it today b/c the line had to start back up.
I need to pull part numbers and look some things up and talk to the machine builder to put all the facts together, but I actually feel much better having found something so significantly wrong.
Once I confirm what I have vs. what I'm supposed to have, etc etc, I'll post an update.
Thanks again for all the support, it was very helpful.
B.
Reminder:
B.
