gas said:I have seen some dumb safety things but I have also seen some dumb things at the other end of the scale.
I recently worked at a plant that makes candles. After a production run a very pregnant young woman had to climb up on a wax covered stool to pull a plug to stop a hot wax pump. All the motors and heaters were controlled by plugging or unplugging, they were all out of reach overhead, they were fed from different sources AND they had the ground cut off.
The whole plant was like that. The OSHA inspector stepped over a 250 volt rubber cord going across an isle (carring 480v) to inspect a machine someone got pinched in. This was one of the few safe machines and they got fined for that. He never looked at anything else.
I couldn't believe seeing that.
Any lawers in the house willing to make an easy buck? Sounds like a juicy case to me...gas said:I couldn't believe seeing that.
They call them "Hard Hats" and are used in many locations (probably where too many people bumped their heads.)jstolaruk said:Wouldn't it have been easier/quicker/cheaper to wrap the mechanic's head with a foam cushion?
MikeW said:They call them "Hard Hats" and are used in many locations (probably where too many people bumped their heads.)
I have been "clumsy" numerous times when crawling about inside various "machines" and a hard hats has become part of my PPE in those cases. The safety gurus here have got us to be world class safe at the expense of going overboard at times - the tool crib will also issue baseball style "bump hats" if you do not want to wear a heavier hard hat when there is nothing overhead that may be a problem.jstolaruk said:I'm kidding; the foam cushion hat is a humorous response for the mechanic's clumsiness. The hard hat is intended for falling objects but this mechanic will probably need that too.
