OT: Magnet Issue
Apr 2002
Just a bit northeast of nowhere
1,117
This one's not directly PLC related, but it is automation related. Perhaps someone has crossed this bridge before:
We have a line where we use 24 VDC electromagnets to grip the parts and move them hither and yon. The problem is, our magnets are holding so much residual magnetism that they don't always *drop* the part when they are turned off.
These are basic magnets, nothing fancy. We tried turning down the voltage with a rheostat, to induce less magnetisim, but if you go a little too far - drop parts prematurely. Too little, and the part hangs around like an unpleasant relative.
We're already fiddling with these things for every different part size (50 of them) and it's proving to be a pain in the ash.
Any suggestions on how to break the part from the magnet effectively?
Thanks!
TM
In the old days I worked with scrap yard magnets. I think they had schemes that put resistors across the magnet when it was turned off. But I also seem to recall something about reverse polarity.
Are the magnets shown to be polarized? If not reverse the power to them and they will demagnetize the core. Of course, eventually you will get the same issue with the south pole.
Can the magnets be run with AC? They might have a spec for AC volts.
Hello everyone, I'm new to the world of servos. And now I'm facing the next problem: I have a SEW Movidrive MDX61B and an Indramat MAC071C...
1,543
I can't seem to increase torque to the desired level w/o the motor just sitting there shaking itself to death. I can only get 80 foot lbs after...
23
4,885
I have 2 permanent magnet 4 phase dc servos driving a cut off knife each level OEM propitiatory (Marquip) with their drives. I have one level not...
1,904
Some VFDs support permanent magnet motors. For instance ABB ACS355. Has anyone tried using anything like this? What VFD / motor did you use...
16
7,581
Hello all, This is possibly a little off topic for this board but I thought I would see if anyone on here knew of anything. What I'm looking for...
3,640
