ChuckM Member Join Date Aug 2003 Posts 266 Mar 20, 2005 #16 You can do a repair install of Windows without having to reformat or reinstall all you programs. If Windows will recognize that this is something that you want repaired though I have no idea.
darrenj Member D Join Date Feb 2005 Location Ottawa Posts 1,003 Mar 20, 2005 #17 try this site..you may be able to find something http://www.kellys-korner-xp.com/xp_tweaks.htm or http://www.theeldergeek.com/
ChuckM Member Join Date Aug 2003 Posts 266 Mar 20, 2005 #18 Is this what is happening? http://windowsxp.mvps.org/foreignlang.htm
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,576 Mar 20, 2005 #19 ChuckM - you did it! this is exact problem I am having and renaming MFC42LOC.DLL file fixed the problem! Thanks! At least day ended on the positive note... It was a disaster day...
Eric Nelson Lifetime Supporting Member + Moderator OP Join Date Apr 2002 Location Randolph, NJ Posts 4,346 Mar 20, 2005 #20 The question marks have vanished!... Yup, that did it, Chuck!... Time to change the shirt logo, Phil: PLC Programming Questions (and many others) ...Answered! :site: -Eric P.S. I renamed my mfc42loc.dll to thanks.chuck... Last edited: Mar 20, 2005
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,576 Mar 20, 2005 #21 May be time for a next question - see my new post.
Eugen Lifetime Supporting Member Join Date Apr 2004 Location Toronto Posts 113 Mar 21, 2005 #22 I found two utilities that will record every file Filemon and registry key Regmon of the application. You can install this utilities .. and run this on both computers .. and then with elimination find the file or registry key causing the trouble. Aren't you glad I did not find this earlier ??
Rick Densing Member R Join Date Apr 2002 Location Milwaukee, WI Posts 1,538 Mar 21, 2005 #23 Contr_Conn said: Eric, What you described is exactly same om my laptop (Windows XP Pro SP1)for almost 2 years except it speaks German or another similar language. Click to expand... I have the same problem, came after installing the WinHMI software from Indramat. I am going to try your solution.
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,576 Mar 21, 2005 #24 WinHMI software from Indramat Click to expand... I have it installed also and problems started that time. I also think E-designer is involved somehow...
Rick Densing Member R Join Date Apr 2002 Location Milwaukee, WI Posts 1,538 Mar 21, 2005 #25 I have the same dialog box as you and don't have e-designer. Renameing that file seems to have fixed it. Last edited: Mar 21, 2005
Contr_Conn Member Join Date Sep 2003 Location Ohio Posts 2,576 Mar 21, 2005 #26 I think as soon as you get this file it will affect all non-English written programs. So I may get it twice or more times with different applications.
Eric Nelson Lifetime Supporting Member + Moderator OP Join Date Apr 2002 Location Randolph, NJ Posts 4,346 Mar 21, 2005 #27 Followup... Chuck's solution cured my Win98 Desktop PC as well... -Eric
Rick Densing Member R Join Date Apr 2002 Location Milwaukee, WI Posts 1,538 Apr 7, 2005 #28 Deleting that file worked for me, however, it came back.
