OT: Non-contact thermometers
Doug-P
Jun 2003
Pa
1,248
I'm considering an infrared thermometer to check contactors and heater blocks and such to head off problems like burnt wiring and downtime.
I've seen a Fluke for ~$800 with 80:1 sensing and some ~$90-~$150 models with 6:1 or 8:1 sensing.
Is $800 too much to spend for what I want? Is there any great advantage to the 80:1 capability?
I think $800.00 is too much.
If you are just checking for hot leads it seems like the $89.95 Fluke would be sufficient.
We have the 89.95 Fluke in our shop. Partner hates it because he feels it is inaccurate. In part he is correct - for our applications - he wants 2 or 3 degree resolution - he will not get it due to emissivity.
For switchgear and contactor work where you are looking for hot spots ie 50F or more greater than ambient or adjacent equipment I think the Fluke is perfect.
Dan Bentler
hmm, I also have the low cost fluke. I work in a blown film extrusion plant. I rarely use it because if I shoot it onto a shiny surface I get say 80 deg, when I shoot it in a very nearby spot onto a cap head bolt (dark matt colour) i'll get 180 deg. Something about efficacy so I read somewhere onetime.
I was at "The Source" previously known as "Radio Shack" a few weeks back, they had a small point and read thermometer the size of a car remote entry fob for $11, I thought it was too good to be true but when I tried it pointing at a pot boiling on the stove it turned out to be quite accurate.
I use it on my motorbike to measure cylinder temperature etc. it's really good when troubleshooting a multi cylinder machine.
The $89 Fluke should be a handy tool.
I'm using fluke 568 but I don't know price.
<we have a fluke at the shop, in the instructions it says, to determine temp from shiny objects like stainless pipe, you need to paint a small square with flat black paint.
Actually if you want a good / true indication of loose wires, contactors overheating etc, I would suggest you hire a contractor with a thermal camera. It will probably cost 800$ or more for the survey but is well worth it.
We have a customer asking us to measure the temperature of a moving chrome covered roll that is near room temperature. We aren't allowed to paint...
2,428
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,742
Anyone out there have experience with non-contact length measurement? If so, please share your successes and lessons learned. I am looking for a...
2,293
We've had an intermittent issue with this for years. The application is sensing a level, or more accurately the absence of level in smallish ~5-10...
7,453
I need to replace the measuring wheel of a cutting system. Problem is that I do not have enough space in the machine and the cutting process is so...
2,136
