Ot:piping system
osmanmom
Mar 2014
JOHOR
1,457
I need few tips, info or suggestion about this piping system which one more suitable,
Or any advantage or disadvantage using this type of design.
Water pressure about 6 to 10 bar, 4-6 inch pipe, material PVC/Poly type
Thanks in advance.
Thanks for the reply,
The formula is the main.
Another question if possible to answer what process will happen on the circle at extent pipe (attachment piping-1)
And attachment piping-2 is the diameter size
What will happen on the pressure flow if only 2 pump delivery the water with different pressure Bar.?
First of all, unless you want to pay for custom fabrication the radiused entrance can't be done as drawn. This is usually accomplished with 45 degree wye fittings into the main header and a 45 degree elbow into the laterals. Second, the blank end of the main header is usually a square, with the closure being accomplished with a cap or a blind flange depending on the diameter. Third, a trivial but often ignored concern is that the main header should be three times the cross sectional area, not three times the diameter, of the laterals.
By definition your two pumps cannot and will not operate at different pressures. They are discharging into a common point, so they will see the same discharge pressure. (We will ignore the negligible pressure drop from flow through the header.)
If you meant to ask what happens if only two pumps are running instead of three, that depends. If most of your head (pressure) is static not much will change.
If most of you head is friction the result depends on pump type. If they are centrifugal pumps each will increase in flow and you will have more than 2/3 of the original flow. If they are positive displacement pumps the flow per pump will stay the same.
We have a system that has 1 inch pipe though the whole circuit ( cooling water ) and the control valve body is 1 ½. This is the only circuit like...
1,863
I have a question about transitioning from EMT conduit to a device. For example this device, 24VDC with PNP output, does not contain a NPT...
2,343
hi, can anyone guide me on how to go with freeze protection on piping, is there any standard products available or that is something to be...
2,312
Greetings Again! I would like to create some "pretty" 3D-type process piping on a RSView32 Graphic. I attend to animate this piping with color...
2,122
Hello, I have no training in maintaining potable water systems, so forgive me if some of my terminology is far off the mark or if I'm focusing on...
96
