Set points on a triplex system
indykins
Apr 2024
Granite Falls, WA
Hello,
I have no training in maintaining potable water systems, so forgive me if some of my terminology is far off the mark or if I'm focusing on the wrong things. I have a VFD controlled triplex system (each pump with it's own VFD), with 3 variable rate pumps, each run by a 5hp, 60Hz motor. Each pump has about a 45gpm discharge rate at 100%, and they're all set up in an alternating lead, lag, lag configuration. I need to maintain a constant 70psi output pressure. The water system normally uses between 5-100gpm each day... averaging about 20gpm over a week. Lead pump is currently set to alternate every 12 hours.
I don't have any user manuals for the system and I'm unable to readily find anything online, but I'd like to confirm that the current set points are at least in the ball park. The system currently runs smoothly enough, however I recently had one pump go down and I've noticed some wide pressure fluctuations while it's been offline during repairs, which I'm assuming may be due to the hand off protocol for the two remaining pumps. Do you guys have any suggestions?
I'll see if I can't attach a picture of the lead pump setup screen.
Hi, I´m using the modbus slave program from Rockwell and I want to syncrhonize some set points. My problem is that when I send values to the CLX...
1,320
I am designing an hvac control system for my new 4800 sf office. I am going to use a server quality PC running in a clean conditioned environment...
9,882
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
26
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
Omron AD081-V1 Analog Input Card Offset & Gain Adjustment Entering Adjustment Mode 1. Set the input card in adjustment mode (Turn ON Dip SW No-1)...
92
