OT: Process Equipment Tags, European?
Ken Moore
May 2004
North, West, South Carolina
3,475
Hi folks,
I have encountered two different plants (Both having Siemens PCS-7 control systems) where the tags/symbols for the Equipment was different from what I'm used to, but they both used the same "standard". One had ties to Spain, and the other Germany.
Example:
Pump tags start with "GA", such as GA-100.
Mixers start with GD, ...GD-101
Reactors: DC-103
Tanks, some are FA, some are FB, not sure what the difference is.
FA-104 or FB-105
If anyone is familiar with these, can you point me to a reference for them?
I'm not, but is it possible that one is a closed (pressurised) tank and one is an open tank?
In the EU, the references of sensors and actuators should follow EN81346-2, unless you have a custom system which then must be documented.
In EN81346-2,
"GA" is for "Generating electrical energy powered by mechanical energy".
"FA" is for "Protecting object related to overvoltages".
"DC", "GD" does not exist.
The description of the tag names you listed does not match EN81346-2, so they must have a locally defined custom system.
Hello guys, I'm working on a plant which will be automated with pcs7 from siemens. I have some trouble to define the plantstructure according to...
4,779
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
81
Hi All, Im using Cimplicity 8.2. after the last restart Server Scada, the PTDL_RP process can not running. so Process can not be login to database...
160
Hello parky, goghie, Brian and all of you who kindly come to help when I get stuck. I cannot look into the clock issue that parki has written for...
859
Hi, When I use an interrupt OB (let's say OB38 which is processed every 10ms), does it read the state of the inputs at the time it is called, or...
18
2,393
