OT: Pushbuttons
Determine what kind of bulb you will use first.
The transformer module has a very small transformer in it that steps down an AC control voltage to bulb voltage when using 6V low voltage bulbs. Transformers are available for a wide variety of control voltages.
The resistor module limits the current and provides an inline voltage drop for neon bulbs.
None is for non-illuminated buttons, there won't be a bulb holder or power module.
If the bulb voltage matches the control voltage then choose full voltage.
Alaric
What are the dual input and full voltage? How do they work?
It is a 800T seires pushbutton that I am trying to configure.
I want to use LED for the light if possible and I will be using 24 vdc power.
Hi Tim,
A lot of machinery uses 120V control circuits.
120V bulbs had too thin of a filament, and would break due to machine vibration.
Allen Bradley and other MFRS puts step down coils right on the pushbutton switches or pilot lights.
These transformers step the voltage down so that thicker filament Lower voltage bulbs (More Robust) can be used.
Of course now we use LEDS.
Vibration is no longer an issue, and there are quite a few more reasons to use LEDS.
One thing to keep in mind, when using buttons with the transformers, is it adds to the overall depth required. Verify you have room wherever you are locating them, for the additional depth. You should be able to see the demensions on-line.
Does someone know if there exist pushbuttons directly on Ethercat? I know we could guide standard pushbuttons to a Ethercat IO module, but we are...
776
Good Morning , I would like to start a Powerflex 525 with a N.O. Start Pushbutton , and when the N.O. Start Pushbutton is released I would...
1,695
Hi, Like the subject say I would like to know when are extended or raised operator allowed for a start function. The machine in question...
4,038
Hello, Controllogix 5572 with Studio 5000 v33 and FactoryTalk View SE v12. Is there a way to force I/O bits using HMI pushbuttons? I've tried...
2,901
Hello, When it comes to process control (e.g starting/pausing/stopping a batch or sanitation function) with HMI pushbuttons, what is the...
3,010
