OT: Question GFor Those Excel Master
I_Automation
Jun 2020
Detroit, Michigan USA
1,653
I know some of you here have responded with examples of Excel mastery and I am a self-taught beginner, 2nd level.
I have asked around in the offices of customers and no real answer to this, and I am thinking this must exist somewhere or be a macro that can be created.
I have created a simple spreadsheet as an example for marble inventory attached. The first column is individual marbles, the second packages of 5 marbles. etc. I have a sum that multiplies the packages by the top row quantity and lets me see how many total I have.
My like is I would like in every quantity cell a + or -, or < or >, to add or subtract one to/from the value in the cell,
Online I found the suggestion to add 2 to cell A1 enter =A1+2 in A1, but that faults and shows an error in A1.
Is there an existing way, or a way to create a macro to do this?
Thanks in advance and I'll buy pizza.
EDIT: I have searched and checked inventory spreadsheets but have not found anything like this in them.
  • Marbles.zip
chelton said:
Do you mean a spinner
Thats the issue with excel, you need to know the terminology... if you know that the rest is easy to find
Thanks chelton, I will be using that one also 🍻
After getting this in use and pondering it -
I have one question - for Bill Gates: [and sort of a rant]
What is this 'spinning'? To 'spin' it would go around. If the limits are 1 to 100 then at 100 the next UP would spin around to 1. Your staff just open a dictionary to a random page and throw darts at it to name things?
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
170
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
155
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
247
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
111
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
203
