OT: RS-232 to Bluetooth
Bullzi
Jun 2012
Colorado
1,530
Hello Everyone,
We have a Data Acquisition Device that we normally connect to our laptop via a 232 connection. Since the device is on a trailer and the computer is in the truck cab the guys run a cable between the units every time they get on a job. Since they connect and disconnect several times a day the cables get worn out and cause issues.
To help with this we recently bought a RS-232 to Bluetooth adapter to avoid having to run the cable between the device and the computer.
The issue I see here I see here is the software on our laptops doesn't have a driver to go get the info from the Bluetooth interface. Has anyone done anything like this? Is there a way to map Bluetooth over to a COM Port? Any help would be appreciated.
Thanks!!
Ok so when you install the unit it creates its own COM port. Then all we need to do is make sure to select the same port on our software and we should be good.
Thanks for the help!!
Hello Guys! I have a problem with a wireless-bluetooth communication between a plc and a panel (if I use a rs232 cable the communication works...
4,039
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
151
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
104
Hello: I have to connect a RS232 Modbus RTU slave that only has Tx, Rx and GND signals to a Modbus RTU master. However, all RS232 to RS485...
248
Hi to everybody. I need to read the first 12 characters of the message that a barcode reader sends to the ascii card (1734-rs232 ascii) and I...
735
