OT: Small Pipe Temperature Sensor
ASF
Jun 2012
Australia
3,921
Hi all,
Related to my other post, I also need to measure some quite low temperatures (down to -50°C) in pipes. For the most part this is fine - I'll just put a thermowell in the pipe and put an RTD with a 4-20mA "hockey puck" in the head. However, some of the locations I need to measure the temperature, the pipes are only 20-30mm diameter, making thermowells impractical.
Any suggestions for monitoring temperature in that application? The pipes will be lagged, and I'd ideally like something that is replaceable/serviceable without removing the lagging.
Stick it in a 90° bend and have it as long as you like, and also facing the direction of flow?
OR
IFM TA2105? Your fluid will fall out if you replace the sensor though.
The turck looks like it could be what I'm after. Unlike the IFM, it seems that the RTD is detachable from the sensor electronics, so as long as the RTD itself was all good I could replace the sensor without breaking into the pipe.
Putting it in a 90 degree bend was my first thought, but in a 20mm pipe it's still going to take up a lot of space. It might get to the point of having to tell them to try again with larger pipes, but I'm trying to work with them as much as I can first.
I'm trying to avoid surface mount stuff, because it's just not very industrial, and also it would be buried under lagging and impossible to maintain.
I'll check out the turck...anyone know of any other brands that do a similar thing, for comparison purposes?
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
714
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
330
Hi! I'm wondering if PLCs are used for small-scale production. I've got four machines doing different things with textiles, and I'm exploring the...
1,340
I am looking at an application where I will need to detect small hairline cracks in stamped metal parts. The sensing will need to be done in the...
1,143
Anyone know what the little green triangle on SCREEN 3 means ? See picture Thanks
457
