OT - Terminating Field Devices
brucechase
Sep 2004
Augusta GA
721
Since there has been several of these types of how (or what) do you do for this, I thought I would ask something that I've been curious about. How do you terminate a field device?
My system has over 1000 photoeyes, 200 prox switches, and countless PB, switches, and solenoid valves. My question pertains to the photoeyes and prox switches. The current way is to run to a FS box and crimp the quick connect cable to the field wires using "bullets" NOT butt splices (see image). The original installation used sleeveless connectors with a rubber boot that snaps over the splice.
I try to use small terminal blocks in connecting field devices in junction boxes or conduit outlet bodies. They take a little more room, but they are tight connections and make disconnecting for service or replacement easier. I use the little white ones from Radio Shack or Panduit.
Hi all, We are installing a number of Profibus actuated valves (Auma AC 01.2). They have a terminating resistor on the PCB but the system...
926
Good Morning, I am young and learning the automation industry. As you all know, alot of communication these days is all Etherent. Though there are...
6,668
Hi, I'm just making some notes about the resistors for DH & RIO networks. I know the advice is for 150ohm for 57 - 115k, and 82 Ohms for...
1,879
Hi all, I am using a Kuebler encoder in our machine, it is profibus communicable and has M12 type ports. There are 3 M12 ports, 1st for profibus...
1,941
I am working with a simple PLC to HMI to HMI DH+ network that has a Graceport programming terminal at the end of the blue hose on the DH+ network...
3,222
