allscott
- Join Date
- Jul 2004
- Posts
- 1,332
Can you post a hydraulic schematic of what you have? Is there a safety relief valve in the circuit? How long does it take the breaker to trip out after you have raised the pressure? Is there an overload on the motor circuit, is that is what is tripping or is the actual circuit breaker for the motor?
I am still pretty sure that your problem is hydraulic and not electrical. The problem is not that your breaker is tripping, the problem is that your motor is overloaded.
It almost sounds like you are stalling the motor. I've stalled hydraulic pump motors because of a defective relief valve. It's not pretty, if there is nowhere for the oil to go the pressure will jump DANGEROUSLY.
I'm Jack, as in Jack of all trades. I am not a motor or hydraulic expert. Having said that this shouldn't be a difficult problem to troubleshoot with the right information.
To answer your last question remember;
P = E*I
If E goes down I has to go up to supply the same pwoer.
P = E*I
