out of 5 contacts only 2 should run
You might have guessed by now by the sarcastic and one line answers that you have not added anywhere near enough detail for anybody to help you.
I would argue that he did give enough information for people not to want to be involved with this doubt. If you don't know how to interlock a motor either via PLC or electrically then there's a lot he should know before attempting any of this.
Yes of course but i thought it would throw them a line and let them come back with at least something a bit more detailed.
IMO - We should just not reply to these types of posts. Obviously, they don't give anything back to the community and they don't read other posts to see how to properly ask questions.
I think i need to comeup with a better way to post the questions, sorry for the time wasted. Let me figure out the best way to put this question maybe with some pictures.
Sorry & Thanks!
As I stated earlier,
what is your plc?
describe your application.
it's not that we don't want to help you, we can't based on the information you have provided.
by writing out your application, you have a roadmap telling you what to do
with specific information, no guess work.
james
Hello guys, I will try to summarize my problem as follows Problem: ---------- I want to monitor the status (& also remote control) of a UL489...
3,305
Are 24VDC contacts for PB's allowed to be exposed? I have an application where a control panel was put in with the contacts showing on the back...
1,828
Good Morning , A co-worker installed a Allen Bradley MatGuard this weekend . They were not able to get it to work . He was using a MatGuard...
1,109
Is there an electrical code requirement that calls out the a need for an auxiliary contact in a field mounted disconnect? I have a customer that...
21
7,795
Has anyone found a cost effective way to get dry contacts (for robot fence and estop inputs) from a safety PLC digital output? I'm using the...
2,380
