Exposed 24V Contacts
Timeismoney08
Jul 2012
United States
312
Are 24VDC contacts for PB's allowed to be exposed? I have an application where a control panel was put in with the contacts showing on the back side (inside of the machine itself). I know it's safe from electrocution, but obviously not safe from water (even though there's no threat).
Thanks in advance!
It all depends on the hazard rating, environment, and standards you are trying to meet. With most pushbuttons, if they are installed correctly they will seal against water and other contaminants. Therefore, if they are installed in a properly rated NEMA enclosure, the back side of the contacts cannot get wet. You can buy finger safe and other type of contacts as well when you specify pushbuttons.
This is first post. The time I follow this place, dynamic and fast, beyond complete solutions, accurate and easy. One of the best ones, this is...
18
4,873
I am replacing a 1756-OB16E 16 point 10-31 V DC card with the above card in a 16 slot Rack with a 1756-L71 control Logix 5570 controller. The...
552
Hi, I've bought this PLC + HMI from Aliexpress, the one on the right that uses SSRs. and want to connect a 24V/0.2A DC fan to the output. My...
32
7,103
Hi Everyone, Is it Possible to downgrade to Program from version 32 to 24version..? Because I have 24 version and the program which I am going to...
1,079
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,264
