No PWM especially on the relay model,
But what do DA0 & DA1 do ? Aren't these pin the ones which provide PWM signal ? Or what do they do exactly ?
some transistor outputs will allow a sort of PWM
Yes, I know that on a transistor I can do PWM or similar pulse based on how fast the MOSFET can switch ON/OFF. But it's not practical to do it on a mechanical relays or SSRs.
but I doubt the clone will be able to use that instruction only the real FX3 is capable I suspect
ok, actually I didn't know that there are real FX3 controller boards. I thought this board is a simulation of the known high performance PLCs; like, siemens PLCs.
I learned that siemens uses high performance chips; like, SoC or ASICs and not microcontrollers.
there are a number of differences between the real Fx range & these clones. A friend of mine has one I will ask him to try it on the transistor output model to see if it works, so it may be possible to use PWM function with transistor outputs but not on the relay one.
No, it's OK, I know on the relay output it's not practical but on the other pins that are coming directly from the MCU, it's possible.
