High speed 150V DC Switching source to control piezoelectric motor
PreLC
Apr 2019
Mars
587
Does anyone have any experience with working on piezoelectric motor control? I want to use off the shelf components to hopefully change the motor's oscillation frequency in real time.
Why not use a DC drive, you can adjust the output voltage to what you
A 250VDC SCR drive will work for that, just adjust the output voltage for the 150VDC you want. You want to consider putting a capacitor on the output to smooth out the wave form
How much current ?
I am actually unsure how to find out the current. In the datasheet for the actuator, it only lists a capacitance. Maybe I'll have to use a resistor in series to complete the circuit? I'm assuming really low currents(Few mA).
I did some basic mechanical power to electrical power equivalence calculations also, seems like for 20-100 Hz, I will need 8-50mA. Maybe a factor of safety is needed too?
What is the switching frequency ?
I require about 20-100 Hz for my process to execute.
I'll be honest, I've only used AC SCRs(Control Concept's Microfusion to be precise).
The AC SCR's required external AC Source voltage. How does it work for DC SCRs? Do you know any that will run with EIP/EtherCAT?
I would contact these people
AC Drives, DC Drives, Motors & Control Technology | Bardac Drives
they may have something you can use
As for SCR’s they have been the heart of DC drives for well over 30 years
some AC drives use them as well
you should do a little hoe work on how SCR’s and other common components are used and actually work
20 to 100 Hz falls right in the range for a standard AC Drive
Most AC Drives will support over 300 Hz output
We may be able to help you more if we had more information on the application
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
Hello Folks, Has anyone configured a Momentum high speed counter on Unity 13.1. We need the wiring diagram for Momentum High speed counter and...
77
i am bench testing a 1734 -VHSC24 Point I/O High Speed counter module, i cannot find any examples of wiring the outputs from the module. does...
1,393
Hi, I have a setup of one master s7-1200 - three slaves s7-1200 On each of the slaves there is a HSC on a motor for positioning. It generates...
1,079
Looking for suggestions on a pathway for a high speed, variable frequency output for a slitter line. There is a corporate data collection system...
1,688
