Output not coming on , but can force on
GreenBird
Mar 2016
Brighton
Just started learning. I am using a Omron CP1L (CPU L). I am stuck on the simplest circuit. I want to turn on 1 output with 1 input. The input (0.01) is working and the green line goes through it and the rung, however the coil (100.00) does not turn green. Unless force it to turn on at which point it turns green and the indicator light comes on.
I read somewhere that there could be an internal estop in the code.
Help would be awesome
That is normally one of these 3 issues:
1. You didn't load the program into the CPU
2. The CPU is in program mode
3. That rung isn't being processed.
Or you have multiple instances of the same output. so ur rung says it's on but a few rungs later it's turning the bit off. then sends it to the card
Sounds like your processor isnt scanning or processing the rung or bit is being turned off somewhere else like said before
Sounds like its not scanning the routine. I don't know what its called in Omron PLC's but in AB software a JSR in your Main program will enable this routine and allow your logic to work, unless you are working in the Main routine already.
I had a 5/01 CPU give a CPU Fault. It lost the program and I was not able to establish communication with it. I replaced it with a 5/03 we had in...
145
Allen Bradley 5000, After power fails motor automatically starts without initiating start. I am not sure if this is because it is receiving a...
4,327
Hi, I am sure there is a very simple and logical explanation for this but I can't find it. My system uses S-300 plc and there is a pointer used...
2,894
Hi There, I have a filler with a coriolis flowmeter that has died. the filler requires a pulsed output (manufacturer wont edit the program) is...
126
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
82
