Output should not be active
by the way, easy way to tell if you are looking at the right spot is to throw in an always false bit before the OTE.
If you put something that can never be true before it, and it still goes true, then you're looking at the wrong place. It would be turned on somewhere else, the fact that those say they are a fault and alarm... makes me think you have them either more places, or they are not assigned properly in the HMI associated with the system.... like someone assigned those tags to more than just an indicator... and the hmi is forcing them on instead of just using them as an indicator tag.
For diagnostic purposes add a timestamp ONS to the rung, perhaps that will reveal something related to the time of day. like a janitor unplugging something.
I have a project with Factorytalk SE 8.2 and 2 Micrologix 1400. Its basic High, low, and Hi-High level digital inputs in one PLC and 1 output to a...
1,825
Hi. Can someone please help me? My background is computer programming and not PLC's. I was forced into this job at my work because of the slowdown...
38
30,306
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
80
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
172
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
115
