Output Subroutine
benaiahhenry
Sep 2011
Corning, NY
265
Hi Everyone,
I'm sure this has been talked about before but what are your thoughts on using a dedicated output subroutine? Particularly in regards to RSLogix 5000. Are there any upsides/downsides to this technique?
Thanks!
Benaiah
Hi
I always do this so they are updated together at the same time (ok same part of scan) and it makes it easier to find a particular output for fault finding guys. As said before it is a continuous logic routine with no preconditions so is scanned every time
In my experience the first place Bubba is going to look in the program when troubleshooting an actuator that doesn't work is the output instruction. From there he will trace backwards through the program until he finds which permissive is hanging him up. So grouping the outputs makes troubleshooting easier.
Hi There, I have a filler with a coriolis flowmeter that has died. the filler requires a pulsed output (manufacturer wont edit the program) is...
240
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
85
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
185
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
125
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
340
