set-csg
Hi everybody,
I'm using SIEMENS S7 212, one imput (I0.0) which was use in the program will indicate ON on the input LED display when pressed, but the connected output in the network (Q0.0) will not switch ON.
Viewing it on the Program Status, I0.0 will not highlight even if the physical input I0.0 is activated.
Output Q0.0 will activated only if input I0.0 is FORCED only.
All other input works properly.
Does anybody can give explanation to this?
Thanks,
SET
Thanks,
SET
