AT366 Member A Join Date Nov 2022 Location birmingham Posts 1 Nov 20, 2022 #1 Hi, I'm using CX Programmer and just seeing what the best way to trigger an output from the plc clock time would be. I need this to come on at 9am every morning just to send a signal for about 2minutes. thanks
drbitboy Lifetime Supporting Member Join Date Dec 2019 Location Rochester, NY Posts 8,090 Nov 20, 2022 #2 https://www.edata.omron.com.au/eData/PLCs/CJ1/W394-E1-16.pdf#page=310
BITS N BYTES Lifetime Supporting Member B Join Date Jun 2005 Location Miami Beach Posts 484 Nov 20, 2022 #3 You can use the Time Comparison Instructions type DT. Use >=DT 9.00 AND <=DT 9.02
BITS N BYTES Lifetime Supporting Member B Join Date Jun 2005 Location Miami Beach Posts 484 Nov 20, 2022 #4 Example attached
BITS N BYTES Lifetime Supporting Member B Join Date Jun 2005 Location Miami Beach Posts 484 Nov 22, 2022 #5 First MOV should be #0038 -> D300
