DickDV said:
russrmartin, I know you are in a hurry but we simply need more info to help you. I see you have a 5hp probably 460V rated drive. That would be somewhere close to 9 amps continuous output. I need the motor nameplate FLA.
You say the motor is kicking out via the overtemp switch!! What is that? Normally, the drive software provides the overload protection. This can't be a motor internal switch like on single phase motors, or is it?
I can't really tell whether the motor is overheating, the drive is overheating, or the system simply trips open without anything getting too hot. Please advise what's tripping and why.
In your second post you say you've found a 10hp motor with a FLA less than the current rating of a 5hp drive. Now, I don't think so!!!!!!!!!! Something is ****eyed here if that is so.
Please fill us in on these questions.
DickDV,
I'm only replying now because I value your input more than most on this subject. The drive is actually rated for 5 HP heavy duty, 7.5HP normal duty. It is a Powerflex700. I used to user manual charts in Appendix A to get the drive ratings. You are correct, input current rating is 9.5 Amps. Output rating is slightly less than that of the motor at 11 amps, so my previous post was incorrect. The new 10HP motors FLA rating is 13 Amps, so that is correct that we will not realize all of the HP potential of the motor, and we knew this already. The motor cabling is 14 gauge, so even pushing this motor with a 10HP drive should not exceed it's limits.
The motor is kicking out via external motor temp switches which monitor the motor temp(hazardous location precaution from way back when), and shutdown the motor circuit if the temp limit is exceeded. The actual motor size on the mixers today is 5HP heavy duty rating, but the process engineer is completely dissappointed in their performance. (This is an issue they've been putting up with for years.)
Originally a project was launched to fit these mixers with 7.5HP motors to match the drive capability, but size the gearbox and motor frames such that if the move to 10 HP was required, the move would involve electrical hardware, and the same gear reducers could be used. So, gearboxes and motors were specified. The gearboxes have a 1 week lead time, unfortunately, the 7.5HP motors as I mentioned before are a 6-8 week lead time.
Also not a possibility is drive replacement coupled with new motor cable as it would require new piping in a classified area and would take time that we simply don't have.(This is also why a new cooling unit is not a possibility) So, the only solution at the moment we're pursuing is getting the 10HP motors which have a very short lead time onsite, get the new system together, and attempt to run them. The hope is that the 7.5HP drive will flux up and run the 10HP motors without an issue.
I had never seen this done before, hence my post here. While I think everyone here agrees that long term this should not be the solution, but it appears to be the only one which yields a result of possibly having runable systems in place in 5 days or less.
I believe the long term plan will be to see if the 7.5 HP drive becomes the weak link, or if it is rated large enough to serve the process. If not, the drive system will be replaced with 10HP hardware, which surely should cover it. However, this would be done during a planned shutdown of the process. If it will run it, I would surely hope that we would order the 7.5HP specified motors and install them at a known specified time.
Given that information, my hope is that you might be confident in the drive's ability to at least flux up and run the motor temporarily. i.e. 6-8 weeks.
