P_Motor Add-on Instruction - Maintenance Mode
rankhornjp
Dec 2008
Georgia
241
I can't get a newly created motor to latch the output in "Maintenance" mode.
All the other equipment in the application will latch the output and the device will stay in "Starting" mode until you click "Stop.", but a new one that I created today won't. I feel like it is something simple in the setup, but I just can't figure it out.
Control Logix L62
Logix5000 V.20
FTView V. 8.1
Thanks in advance.
are you sure that the code is being scanned/executed? ... did you insert this into a "new" routine - and possibly fail to "call" the routine into operation? ...
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
80
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
230
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
311
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
162
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
