PACSystems Ethernet Error Codes
Chris IWO
Sep 2012
Tabubil
33
Hi ALL,
In the Rx3i controller fault table-the following fault keeps coming-up
"0.4-LAN System-software fault: resuming"
Error Code: 402
Group: 16
Action: 2 Diagnostic
Task Num: 6
28001d001400000004011d000000000c0a88066
Does anyone have the definition of this error code and how I can interpret the error?
Chris
Ok Tedi
PNG
Hi ALL,
Error Code: 402
Group: 16
Task Num: 6
Chris
Ok Tedi
PNG
There is something on the Network that is disrupting communications.
Take this information to GE Tech Support and they may be able to give you some details. The PACsAnalyzer utility gives a little more information also.
Bonjour,
Je rencontre exactement le même problème avec en plus l'erreur 454. Avez vous eu des réponses à ce sujet ?
Merci
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
113
I am a new engineer just graduated and have been tasked with 'documenting a gate station's I/O and functions'. I work for a large utility and...
1,595
I have a possible application where an existing RX3i processor will need to get ASCII data over serial from a device (and no, I have no other...
2,629
Hello everyone. I'd like to give you a bit of background on me to start off. I've been working in control systems integration for 10 years...
2,689
All, Has anyone come across this new plc from GE fanuc? The vendor's brochures are quite impressive (as usual) ... but I have not knowledge of any...
1,710
