Paging via PLC
Firejo
Jun 2008
Redmond, WA
1,507
Has anybody ever used the channel 0 port of a SLC5/05 and/or Micro 1500 to do paging or better yet E-mailing?
I sure haven't.
I think it more efficient to use PLC's for machine control, and to get a paging system for paging and a computer for E-mail.
We do, but we route it through the network rather than a serial port.
We use Cimplicity, and it works very well.
As for the serial port, I suppose that you can connect a serial-to-ethernet converter and pump out fault codes from the PLC.
Then convert the fault codes to fault messages and then email them out to whomever.
We do paging, email etc...
But.... we do it with OPC on a PC and this alarming package:
http://www.exele.com/Products/TopView/topview_versions_opc.htm
It supports voice modems, data modems, or email via an email server.
Easy to setup and great tech support.
For something slightly different see this thread:
http://www.plctalk.net/qanda/showthread.php?t=24796&highlight=cell+phone
You can get a sample program for dialing a cell phone with a ML1500 here:
http://forums.mrplc.com/index.php?download=293
And read an article about above code here:
http://www.mrplc.com/kb/index.php?page=index_v2&id=67&c=12
I am looking for possible solutions for an alarm paging system that would meet the following requirements. - Alarm source is a 1756-L71 Processor...
4,292
I've looked around for something like this but haven't found much. I was hoping someone here had seen/heard of something like what I need...
2,554
Hi all I am new to this forum and I am not sure if this question/s have already been answered. I have hit a brick wall. I am one of the...
5,548
Has anyone use the 9300-RAPMKIT modem kit from AB? You are suppose to be able to send out pages directly from the PLC to the modem and then to...
2,009
Is there anyone out there using the following alarm paging setup. Wonderware Intouch Alarm query ----> Intouch AlarmPrinter program -----> com...
2,656
