Panel View+1500 communication setup
angi
Jan 2010
us
361
Hi guys
There is a question about how to setup communication for PV+1500:
I use RSLinx enterprise to setup the communication between CompactLogix 1769-L32E/A and PV+ using Ethernet Bridge(1769-L32E), after adding the processor to the network, the address for the communication port did not show up, the only thing I could do was to select slot number for the processor.
How to setup the port address?
I don't understand the question.
In FactoryTalk View Studio, you configure Shortcuts to point to the CompactLogix CPU itself.
This is a four-step process for a ControlLogix or CompactLogix that is connected to the same Ethernet network as the development computer.
1. Create a Shortcut name.
2. Browse to the ControlLogix or CompactLogix CPU
3. Click the "Apply" button to associate the Shortcut with the controller.
4. Copy the Shortcut, drivers, and network configuration to the Runtime tab
Hi Ken
I did the same thing as you, the problem for me is the local adapter did not show up.
You don't need to see the "Local Adapter", just the CompactLogix CPU.
If RSLinx Enterprise can browse to the CPU, that's all you need.
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
56
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
102
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
230
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
421
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
99
