Panel View 550 DH485 with Printer Port
Bill@PSI
Mar 2006
Itasca IL
I have an Allen Bradley Panelview 550. It was originally bought with RS232 DF1 communication and a printer port. I changed the firmwre to use as DH485 comm but the printer port is now being used for the DH485 communication. It will not communicate through the original 232 communication port. How do I or can I still print from this panelview?
The part # is 2711-T5A16L1 but with the firmware change it's actually a 2711-T5A9L1
from the AB website
¬ Terminals with DH-485 communications require application file uploads/downloads through the communication port. The RS-232 printer port on these terminals is for printing only.
I don't know how this applies to a unit that has had its firmware changed; should work.
Panelview 550 DH485 with Printer
Thanks for the reply but the panelview has 2 DB9 connectors. 1 designated for the printer and 1 for the DF1/DH485 communications. For some reason when I downloaded the new firmware (through the printer DB9 RS232)I can only get communication to the other nodes on the DH485 when I'm plugged into the printer DB9 RS232, and I can't communicate through the DB9 RS232 communication port. I know it sounds strange but has anyone ever experienced this before?
Go into your Panelbuilder program and go to Application Settings, Terminal Setup. At the bottom under auxillary port usage is it set to download or printer?
Panelview 550 serial printing to a parrallel printer
Hi, The auxillary port is configured for printing. The next task at hand is printing from the serial port of the Panelview to a parrallel printer. Is this possible or do I have to buy a serial printer? I'm researching an initialization string for a deskjet. If anyone has experience please help.
When you convert a DF1 / Printer terminal to DH485 runtime firmware, the printer port becomes the DH485 port and the original comms port is disabled.
I can't explain the hardware involved, but that's the way it works. If you need the printing function you're going to have to get a terminal that was built to do that with the protocol you need.
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,434
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,925
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,770
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,041
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,776
