Panel View 550 firmware upgrade from DH485 to Df1 communication
zmaher
Aug 2006
Pirot
I have Panel View 550 with only one RS232 port, which has DH485 communication. I've read on this forum that PanelView Standard terminals with only RS-232 ports can run either the DF1 or DH485 firmware. I want to upgrade the firmware so this panel use the DF1 communication, but I don't know where to find firmware upgrade file. Can someone help me on this topic (send me web adress for file download or send me the file)?
There are two distributions of the firmware; one for loading via the comms port, and one for loading via the ATA Flash card. I need the distribution for loading via the comm port becouse I don't have the ATA Flash card.
Hello all, I have a Panelview 550 Cat 2711-K5A5 that has one Serial port ( RS-232). Which I can talk to via my cable via DF1. Which is weird...
2,436
Good evening partners, ist my first question on forum, i hope receive any answer. I need make a cable DH485 for communicate an Panel View 550...
2,929
Hello, I have a panel View 550 that went bad , a new one has been installed , when you power up the PV it looks as it did before except there are...
1,773
Panel view CAT number 2711-K5A2 Getting fault "612 No active mode found on network" Not sure if connected correctly and channel configuration is...
2,045
Hi All - I know that this has been covered off previously but I can't find the right solution. I have a: PanelView 550 2711-T5A2L1X 4.41 Connected...
2,777
