PanelBuilder32 and 1747-UIC with PV300 Micro
Ken Roach
Apr 2002
Seattle, WA
17,490
This morning there was a post in the Practice Area that I'm re-posting here for consideration by the Forum community, with some edits for clarity.
I read about another user posting about using PanelBuilder32 and a PanelView 300 Micro having problems with setting up comms in Windows XP SP3 using the 1747-UIC driver.
I have the 1747-UIC driver running; I can't remember if I used Autoconfigure or not, just that the driver is running. I am running RSLinx Classic as an Application, not a Service.
In RSWho, the Workstation shows up but the PanelView 300 Micro doesn't.
My PanelView part number is 2711-M3A19L1, which is DH485 over RS-232. I am using an aftermarket 1747-UIC adapter.
I've read that there is an issue in Windows XP SP3 involving Serenum.sys, but I think that is related to the 1747-PIC/AIC+ adapter.
Are the 1747-UIC units a reliable method of communication, or have I mis-configured RSLinx ?
PanelBuilder32 says there's a timeout, and the Driver Diagnostics displays no replies from the PanelView.
I've had some issues with configuring the adapter; PanelBuilder has at times shown the UIC comms settings and at times has said that COM2 is already in use.
Thanks again, any help would be useful.
I would first double check the comm port the USB adapter has taken under device manager.
Also the cable needed to connect to your PV (300 Micro) is the 1761-CBL-PM02. A null-modem cable.
See PDF below for more info on the UIC
Hi I try to upload the program from our panelview but I can not get. My computer is on Windows 7 Professional 32 bits. I use the universal...
27
11,649
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,474
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,095
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,645
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,271
