Panelbuilder32 goto screen on event?
tsmith35
Jun 2008
USA
46
I searched the forums and manual, but didn't see an answer, so here goes: I'm using PB32 on a PV600. I'd like to have a screen appear, when triggered by the PLC, to allow the operator to input a 5-digit employee ID for tracking downtime or equipment problems.
I'm sure there must be a way to trigger a "goto screen" based on a PLC bit value, but I'm just overlooking it. Ideally, the PV would return to the last-used screen once the tracking screen is dismissed. Any ideas?
its the end of the day so here goes.
I don't know of pop up screens in the pv600 but I could be wrong.
you might look into using the screen control registers to get to your screen and do a return.
just a quick answer.
regards,
james
Review 'Screen Changes' - 'by controller' subjects in the help section. In 'Application Settings' you will define a 'Screen Number Tag' under the 'Status Tags' and 'Control Tags' tabs. These will be different locations.
To implement a 'return' to previous' you will have to record the current screen number before changing then command that one when finished. (Some type displays have a 'return to previous' code but this doesn't appear to.)
Solved!
James and Bernie, that's exactly what I was looking for. Thanks! Chapter 20, page 24 in the PB32 manual covers screen control tags, while page 26 covers status tags.
More toys to play with... Thanks, guys!
Hello guys , im new at plc. i have a few questions hopefully someone can help me out. i extracted from an old panelview550 a pba file and...
1,513
Hi guys I'll appreciate for your support. I want to know if there is a way to change the text of a label depending of the numeric value of a tag...
1,102
I can't find what laptop I have our PanelBuilder32 application and license on. And Rockwell no longer supports it. Can someone please update 1...
1,651
A tech at a remote facility had a PV550 **** out (Err 690 DH+ hardware failed). He took it out and sent it to me, and going by the label on the...
1,277
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,619
