Panelmate 3985T Watchdog Time Out
bigsteve
Aug 2020
Memphis area
30
In the past day, on our Panelmate, we've gotten several "Watchdog Time Out" notifications. Usually, they will clear by pressing the cancel button, but a few times, the reload has stalled and we've had to manually reboot the panel by disconnecting the power. There have been no changes to the screen or PLC programming, but we did have a suspected power quality problem Sunday late/Monday early with some 3-phase equipment randomly tripping from the MCC.
So my questions; what causes the watchdog time out on the Panelmate, and how can I correct it?
The only reference to "Watchdog Time Out" error message I can find in my documentation is that it refers to an internal Panel Mate problem, possibly related to power. The suggested remedy is to check to make sure the unit is properly installed and if the problem persists to contact your local distributor. To me the implication is that if the power supply isn't the problem, you should be making arrangements to replace the unit.
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
524
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,277
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,155
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,093
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
