Panelmate Classic Configuration File Compatibity
Ashtabula
May 2015
Portland, OR
We have an old Panelmate 12" 7685T HMI that went out and we are trying to replace it with a Panelmate 7685T-8C (classic) that we had in the store room.
The Panelmate says there is an 'incompatible configuration' error when we upload the original ucf file (used on the old Panelmate). There are no errors during the error check / compilation process.
Any ideas what might be the problem and a solution?
Thanks! Colin
No sorry, haven't seen that before but the error message seems self explanatory.
BTW, you may want to put in a system to get those replaced. Replacements are extremely hard to find and I've got two customers falling over themselves to swap out their Panelmates with something newer.
hi dears
I'm going to replace the panelamte 1700(1775T PMPP 1700 ) to new one panelmate epro(7685T-8C)
I know that i should use power pro configuration editor software to import the .pps file format from the old panelmate into software and convert it to new one, i have used the RS232to USB cable converter to connect panelmate 1700 to my laptop. but i don't know how i could do this configuration edition. note that i can see the .pps file on the panelmate 1700 but i couldn't find and import it on my software,
your help regarding to this issue will be highly appreciated,
best regards
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
528
Does anyone know how I can view the configuration file of a Cutler Hammer *.pps file without the software? I need to see what IO is controlled by...
1,278
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can...
1,159
I have a damaged PanelMate ePro HMI and looking to swap it out with a PView or C-More. I have the Panelmate project but not the Canvas software...
1,095
Does anyone know of a modern HMI that can use or convert a Panelmate PPS file?
1,030
