Panelveiw via SLC500 to Red Lion G306A
PedalsV8
Apr 2013
Maryborough QLD
Iam removing a Panelview600 as it is no longer supported and replacing it with a Red Lion G306A panel the PLC is a SLC500, after much research I was able to export a *.csv via Rslogic500 thanks to your forum, what Im after now is how to Format Rslogic500.csv file that is to be imported into Crimson 3.I have done a test one but it seems to be all over the show. My experiece with HMI's is limited PLC's are not a problem.
TIA Regards Grant
TIA Regards Grant
the CSV file, as you have seen, is an excel Spreadsheet.
I have not done this but will have a look for you later today (I am working on a G306) I would suggest doing an export from the G306 and comparing the CSV files.
Then copy and paist
G306a c3 *.csv file format
I just copy/paste from my RSLogic Export CSV file to the following format I just imported export in Crimson 3 to work out the format
Cell a datatag ; name
Cell b [B9:1/1];plc address in this format
Cell c Extent ; usually 0
Cell d TreatAs ;integer etc
Cell L Label ;K1_RUN ;No spaces
Cell M Description
you can leave the rest blank and adjust the rest in C3
crimson 3 Format Error
Cell B [B009:0001] : C3 reads [b9:0/1]etc as [B009:0000]
When you are in a hurry you make mistakes to much info the last couple of days for this old fella
regards grant
Good Morning, I've been working on an HMI using the Panel View 5000 series. I admittedly was not very good at Factory Talk View Studio, but I...
988
Iam adding recipes to a existing program, and when I go to down olad the updated program I get an error saying " Invalid Length, Bit array cannot...
1,427
Read many post on printing the screens and alarms on a Panelview Plus, but is there a way (or macro) to print a file located on the CF card when a...
1,544
I was asked to modify a SLC500 program with the associated PV1000. I hooked up to the PV1000 485 port and could see the SLC using a 1747_UIC but...
1,208
The options for selecting a key are F1 - F20 and K1 - K20 F1 - F10 are obvious, can anyone tell me how the others map to the remaining keys on the...
1,518
