Panelview 600 DH+ To RIO Conversion
chemdawg
Nov 2012
Milwaukee
31
Hello everyone. I had a Panelview 600 DH+ Standard display which I changed out to a RIO. I know it wasn't the smartest way to go, but it's the only option I had. This is a personal project, so I had to take what I could get. I am using a 5/04 processor and I have a 1747 sn card installed. The sn card has green under comms, and it does communicate with the panel view. However, the program in the panel view needs to be converted to work with the RIO panel view. It's giving me errors to all of my tags now.
I need to know how to setup the new panel view or how to change the tags so that I can use it with my program. Thanks.
This hardware is too old to explain from memory with no details.
Post the original *.PBA application (ZIP it first) and folks might be able to help you sort it out.
Hi there, I have a PannelView 600 connected to a PLC5/40 RIO. But they are not communicating. I have set the PV600 Communication in...
2,336
I am having problems communicating with my panelview 600 via RIO SN located on slot 1 of my 10 slot rack unit. I am using SLC 5/5 controller...
3,861
I am replacing a wired panel (switches, lights, etc..) with a panelview 600, the existing panel is using Flex I/O, with 1747-SN card, I want to...
4,669
I am trying to go to a 504 CPU. and on my hmi I am getting a 9028 error. can someone explain what they mean by change reference?
238
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
487
