Panelview 600 standard
Your question is a little unclear.
Can you tell us what you mean by "two different programs". A ML1200 can only have one program in it.
It can have different subroutines. Try to tell us more about what you are trying to do.
Ok no prob, I was asking if the micrologix 1200 controller can hold two different programs at the same time. After conferring with a technician for a while I belief we have found an answer to the problem. So I think this one might be closed. Thanks for responding Mickey, I truly appreciate it.
Ok this is in dealing with a neff press machine. the company installed lasers on it in order to make sure that a particular operation was done before press. once the laser see that the part has been grounded, it allows the operator to start the press process, the problem i was running into is that the machine runs other parts as well so the logic i put in the machine for the part number needed to be able to turned on, only when operating that specific part number. So thats why i was asking the question of trying to store two programs on one PLC. The Answer was tracing the digital input back through to panel view and finding out what the part selection was using when it pulled up in the PLC, since the panelview and PLC are linked. I found out the Integer number and address it was using and inserted a EQU & NEQ instruction and that allowed selection from back and forward between different part numbers.
Hello All. I have an interesting one for you. I have a brand new Panelview 600 Standard 2711-K6C20 and I'd like to get it to talk to an L81E...
2,014
Hello Everyone, A client site has a PanelView Standard 600 fw: 4.46 application (*.pva) that I am unable to open with PanelBuilder32 vers...
3,431
Hello, I was wondering if anyone remembers how to use the security section of Panelbuilder32. I'm working with a 2711-B6C2L1, PV600. I can't...
3,011
Hello again, I'm pondering the inevitable, that the Allen Bradley HMIs I work with and I'm responsible for, will eventually die. A...
18
5,073
I have a Panel view 600 2711-K6C5 Ser B I went to the Rockwell site to see if I can download older version of Firmware...
9,468
