PanelView 7 Screen Issue: Display Continuously Cycling between two Screens
galivanbr
Jan 2024
Smithfield, VA
I'm working on a system with three Panelview 7's connected in a DLR. The system started having miscellaneous DLR faults and they were supposedly resolved through the standard troubleshooting methods provided by customer support. However, once the DLR faults were seemingly cleared, one of the displays began continuously cycling between the main screen and another screen that you can normally access by hitting a go-to button on the main screen. It just continues cycling between the two and is rendered unusable.
The display was powered down and powered back on, but the issue remained. The ethernet cables were disconnected and reconnected which didn't fix the issue either. Additionally, the troubled Panelview 7 was replaced with another Panelview 7 with the same screens and setup and the new display had the exact same issue.
Also, this same system and set up is being used multiple places and this is the only one having this issue. (The only difference is the length of the ethernet cable runs, but this particular instance of the system doesn't even have particularly long runs)
I haven't had the opportunity to troubleshoot the system in person yet, but I'm at a loss and I've been unable to find an instance of a similar situation online. Has anyone experienced a similar situation and if so how did you resolve it?
Could be the PLC is calling the screen remotely.
Check the tag specified in your panelview's global connections -> Display -> Remote Display number and verify it in your PLC.
I've used this AB PanelView 600 for well over 10 years but notice it is getting harder to see the screen unless looked at it on a obtuse angle...
1,274
I'm attempting to salvage some PanelView Classic 1200 Units and I have two that have a blank white screen when powered on. Has anyone ever seen...
4,640
89
I'm doing my first PanelView 5000 application with Logix View Designer v8, and am of course jumping in headfirst. One thing I don't find is a way...
732
Howdy Everyone, We had to replace a panelview 600 2711-B6c20 the other day and when we did, the new one none of the screen selector buttons work...
1,142
