Panelview C600 USB port connection
AA_Ron
Feb 2016
Minnesota
43
Afternoon folks,
Anyone have any idea where I can find the download for USB RNDIS driver to connect to a C600 Panelview. Looked everywhere and cant seem to find the driver for it. The Component PDF led me to a dead end in the section for connecting Via USB.
Thanks!!!!
From the knowledgebase on Rockwell website:
There is a driver file there : PanelView USB RNDIS Driver.exe - but even zipping it, the file is more than 2MB, so cannot post it here...
118137 | 02/24/2011
Question
I want to program my PanelView Component using a USB connection. Where can I get the USB RNDIS driver for the PanelView Component?
Answer
The driver is available with the Accessory CD that shipped with the unit. If the CD is not available, use driver attached to this note.
Installation instructions, see the PanelView Component User Manual Publication 2711c-um001
Quick start guide, see the PanelView Component Quick Start Publication 2711c-qs001
455067 | 09/01/2011 |
Question
What driver do I use in Windows 7 64-bit to connect to my PanelView Component or PanelView Plus 6 or PanelView Plus 7 via USB?
Answer
There is a RNDIS driver built-into Windows 7, Windows 8, and Windows 8.1 that will allow the PanelView Component or PanelView Plus 6 or PanelView Plus 7 terminals to connect to a Windows 7 64-bit computer.
The following procedure may work on a 32-bit OS if you are having trouble getting our RNDIS driver to install.
The following describes how to add the device:
Open up Device Manager.
Right-click on the PanelView Component or PVc USB Device and select Update driver software.
Note: Windows 8 and Windows 8.1 appears as a unknown device
Click Browse my computer for driver software
Click Let me pick from a list of device drivers on my computer
Click Network adapters and click Next.
Click Microsoft Corporation and click Remote NDIS Compatible Device and click Next
Note: Windows 8 and Windows 8.1 Click Microsoft
Click Close after the driver is updated.
Have a C600 Panelview that the display went out in it. It still has the configuration in it and the equipment is still running. Believe it is just...
1,604
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,573
Hi Guys, I have a Panelview C600 2711C-T6C that one of our clients have and they wont to remote access the screen is there anyway you can do this...
2,906
I recently bought a C600 and I setup the communications so that I could program it throught the ethernet port. I completed a reboot of the system...
2,480
I'm working with a Micrologix 1400 and a Panelview C600. I can get them working together fine over ethernet, but am having trouble getting the...
2,962
