PanelView Component Decimal Display
Mar 2018
Minnesota
22
I am using a PanelView C1000 as the display and a MicroLogix 1400 as the controller. How do I use a floating point address (i.e F8:0) from the controller and have the PanelView display the value to one decimal point? (ex: 5.6)
I've figured out how to get decimal points to display, but I have one value that is not displaying correctly. The value should be displaying as .9 It's displaying as 1,.0 instead. How do I correct this.
Is this a standard terminal with PanelBuilder32
What do you have the Data Type set to on the Tag Form
for the object, I assume you are using a Numeric Data Display Object
It is a standard terminal using the internal PanelView Explorer to edit. The Data Type is set to Real in the Tag form. I am using a numeric display object with the Format set to 1 decimal place.
Does anyone have access to a programmer's manual for this? Specifically, I am looking for instructions for the advanced toolbox objects such as...
1,057
I need to get an upload from a 2711C-T4T. I found an old thread http://www.plctalk.net/qanda/showthread.php?p=734222#post734222 on here that...
1,977
I have a working collection of applications for the PVC C600. the setup is one pvc600 connected to a DH485 network with two micrologix 1200's...
1,583
Hello everyone, I have a 2711C-T4T with firmware 1.80. I am using Connected Components Workbench v10.00 to attempt to download an application to...
2,705
Hello, I am new to the Allen Bradley connected components workbench software. I am working with an AB panelview component Hmi and would like to...
1,201
