PanelView plus 550&600 memory
marwan_13
Sep 2006
Amman-Jordan
28
Is it possible to use any type of ATA flash, or it is mandatory to use the manufacturer's memory to transfer the application of Allen bradley panelview plus 500&600?
In short: No problem.
Rockwell Automation will only provide support or warranty for the devices they sell.
While the A-B units are very high in price compared to commodity devices, the vibration and temperature specifications as well as the assured compatibility and lengthy availability are demanded by customers who have those conditions.
There is nothing technically unique about the A-B devices; they are ordinary FAT16 format ATA Flash and CompactFlash compliant devices.
I use SanDisk brand ATA Flash and CompactFlash devices very often for upload/download and data storage in PanelView and in ControlLogix, but have purchased a few over the years that did not work. CompactFlash compatibility is a more complex topic than you might think.
With PanelView Standard terminals, the ATA memory cards are only used for infrequent copies of files between the terminal and the card. This is the least critical way that the card could be used, and I would be comfortable using any ATA Flash device that had demonstrated compatibility.
There are significant differences between retail multilevel-cell type memory devices with consumer ratings for temperature, vibration, and write cycles and the industrial single-level cell type with higher ratings for environmental and performance factors.
Those are not important for things like PV Standard application transfer. They can be vital for things like ControlLogix data logging.
For the original poster, and for many users, ordinary consumer-grade cards will work fine.
I think the original intent of the question was "is there something special about the A-B card that is required to make it compatible with my terminal" and the answer is no.
Customer has a lot of old PV600 I have been converting over to PVP7 using the adapter plate. Now we have a PV550 (2711-K5A2). Has anyone had...
2,622
99
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
64
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
96
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
98
