Panelview Plus 6 CIP Connection Error
dww5003
Mar 2011
Altoona, PA
Hello All,
I am using a Panelview Plus 1250 terminal connected through ethernet with a control logix chassis that currently only has the processor and an Ethernet card in it.
I am using a thumb drive to load the application and each day when I power up the PLC and panelview it is a chore to get the two to communicate. I keep getting a CIP Connection open end rejected Error, typically after I go to the RSlinx Enterprise Communication Setup under the Terminal Settings and select the path that its already setup to use, eventually they'll start communicating fine.
Everyday its the same thing and I am literally doing the same thing to fix it over and over until it works. I know there is something strange going on here, I should be able to boot up, Load application, Run Application, and go on my merry way.
Any ideas are greatly appreciated...
Hello you all people, I am having a situation I can't understand, if anybody could please explain it to me it would be great. Whenever I download...
13,739
99
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
69
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
96
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
98
