PanelView Plus 6
Narlin
Mar 2010
phoenix
320
[FONT=&quot]I recently upgraded Factory Talk View ME to Release 7.0. When I create a new PanelView application, I don’t get a choice to create it as “PanelView Plus 6” vs “PanelView Plus”. Is this what everyone else sees? Does the PanelView Plus application load onto a “PanelView Plus 6” OIT?[/FONT]
When you create the Runtime file, you will have the opportunity to specify which firmware revision terminal you're going to run it on.
For the PV+6 hardware, you'll have the options to create a 6.0, 6.1, or 7.0 version Runtime.
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
65
117
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
80
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
106
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
109
