Panelview Plus CE, open internet explorer
ltfordnr
Aug 2007
seattle
36
Anyone ever tried to open a pre-determined URL on a panelview plus CE with a go to button to view web servers of different equipment?
Would be nice to view web pages with a touch of a button.
I've never done it before but have an immediate need.....
Use the Program Launcher ActiveX (Objects > ActiveX > ME Program Launcher)
There should be help files on the activeX in FTSTudio for the correct syntax.
Going from memory, the EXE program is iexplore.exe and the parameter would be the web address. What I do not remember is if those need to be in string tags, or if you can type that directly into the activeX connections with quotes.
But that is the way to open web pages; use the Program Launcher ActiveX
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
44
100
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
77
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
98
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
100
