Panelview Plus CompactFlash Firmware
Aabeck
Feb 2013
Detroit
1,860
I am trying to fix an older PanelView Plus 1000 2711P-T10C4D1 Series A Rev C, Logic Module 2711P-RP1 Ser B Rev C.
After replacing a few parts it now shows the firmware is corrupt or missing. The firmware Compact Flash (2711P-RW1, Series C, ver 3.10.04) when put in a computer shows as needing to be formatted. Is this a different format that Windows can't see, or is the flash empty? The external CF card with the .mer project on it is readable in Windows.
If it is a Windows format & I reformat it, could anyone Zip the contents of a working flash of that version & send it to me (searched EBay & none of the listings were for this version).
Tried a Series E, ver 5 flash from another PV1000, but it crashed, need to have the version compatible with the display unit.
I had a similar situation & ended up trashing the Panelview, never found if you could reinstall the firmware if the HMI wouldn't at least power up to the config screen. I think there should be a way - my Rockwell distributor said the only option they could provide was to return the complete unit to Rockwell for a complete rebuild - just to get the compact flash reprogrammed.
Hi guys I need some help how to store tags value to a CompactFlash, in CSV or TXT format, I never tried it before, I am using this system...
3,657
91
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
57
Hello All! Ok, we got a Work cell from a Integrator that is sending saved scanning data from the PLC to HMI (Panel View Plus) when I look at this...
88
Hello everyone. This is more of an HMI issue. I have a new PanelView Plus 7 Series B. I am using the alarm list object to display the fault...
93
