Panelview Plus Fatal Error
frorge
Jun 2011
Texas
Howdy,
I've got a panelview plus unit that recieved some water damage. It is now throwing an error, "Fatal 3a". From what I've found on AB's website that means, "touch stuck" which I take it to mean the touch screen. They then say to replace the screen...
I've replaced the screen for the customer and everything is working great. But out of curiosity have any of y'all seen this issue, and been able to fix it? I wouldn't mind having a spare screen lying around if all i need to do is solder on a new capacitor or something.
Thanks!
**Edit: After some searching I did find this thread: http://www.plctalk.net/qanda/showthread.php?t=81606
Any other suggestions?
I had the same issue with a PV+ that got wet. Sorry, I did not find a way to fix it on site either. The customer purchased a new one and had to send the bad one in for repair. It's not a bad way to end up with a spare unit.
Hey there. I have a PV Plus 1000 FW: 5.10.16.09 I cannot change the communication setup to direct my device shortcut to a different PLC. This...
5,259
hello guys! i have an error in my panelview, I tried everything :( error said: Application MERuntime.exe has performed an illegal operation...
3,766
Hello guys, I have a panelview plus 1000 in which I have downloaded a .mer application but this message always appear :"Fatal Application Error...
9,961
Hey Guys, I have a brand new Panelview Plus 1500 Touch straight out of the box. When I plugged it in and connected it up with an older RP2 logic...
8,305
87
