panelview plus 600 - fatal application error
darienpogi
Jan 2016
United States
20
hello guys!
i have an error in my panelview, I tried everything :(
error said: Application MERuntime.exe has performed an illegal operation and will be shutdown.
my firmware version 5.10.16
i tried to download firmware (3.20.11)(4.00.15)(5.00.09) but always saying not compatible firmware :(
any comments and suggestion will be appreciated
thanyou :)
Hi and welcome to the Forum!...
Is it currently connected to the controller assigned to its shortcut?
That message can appear if disconnected at runtime.
Have a look here also...
57834 - Fatal Application Error, MERUNTIME.exe
Access Level: TechConnect
If you cannot access the above...
The MER file may be corrupted - recompile a new one
The terminal's firmware may be corrupt - re-flash the firmware
An embedded picture may be too large - reduce size
A macro file may have some invalid syntax - correct syntax
What is the actual firmware revision that the terminal is currently using? (not the MER version).
Regards,
George
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
468
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
658
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
631
Hi all, I have an old PanelView Plus 600 (2711PC-T6C20D8) that I am repurposing on our site - I have flashed the firmware to ME version...
983
Hello Team, I have a question, I have been working with a panelview plus 600. But I have deleted all the .mer directly from the HMI, after that I...
1,707
