PanelView Plus 600 only wants to load PanelView Plus 7 MER?
tetcie
Jan 2023
UK
21
Hi all,
I have an old PanelView Plus 600 (2711PC-T6C20D8) that I am repurposing on our site - I have flashed the firmware to ME version 11.0.25.230 (to be in line with all our other HMIs on site) and have created a ME runtime 11.0 application, however, when I transfer an application to the HMI, I get the following error?
Error:
This terminal can only run HMI applications (MERs) designed for Panelview Plus Compact or PanelView Plus 7 Standard Terminals. Please load an appropriate HMI application (MER).
I am fairly new to Allen Bradley and have never worked with PanelView Plus 600 but I am baffled as to why this is happening.
Has anyone seen this before or does anyone have any ideas as to why this is happening?
Oh wow I am an idiot. Apologies everyone, how do you delete a post?
Go to edit the post, then go advanced. Edits are only available for a limited time after posting though, and there may be restrictions on the ability to delete the first post of a thread (I've never tried).
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
469
Hello , I have an HMI of PV+ 600 (2711-T6M5D) Ser A Rev B, This HMI doesn't have the ethernet port i have to take backup through communicate...
659
Hello all, I copied the MER file from one PanelView Plus 600 to another one, using a USB drive. On the new HMI, I copied the MER file to the...
631
Hello Team, I have a question, I have been working with a panelview plus 600. But I have deleted all the .mer directly from the HMI, after that I...
1,707
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
737
